It is currently Thu Aug 14, 2025 8:20 pm
PostPosted: Sun May 31, 2015 9:29 am
First name: Big
Last Name: Jim
I have a guitar that is deep body , 5" to be exact. It has a neck to body joint at 12th fret. I know a standard baritone has a longer scale. Can I fit a set of baritone strings to this and have any success?
Mainly just out of curiosity.
PostPosted: Sun May 31, 2015 9:57 am
scale length has nothing to do with where the body/neck join...
PostPosted: Sun May 31, 2015 10:07 am
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
What is the scale length of the guitar in question? I have a fingerstyle guitar with a 25.7" scale length and I use light gauge strings tuned to DAGGAD. I haven't ever thought about using baritone strings since baritones are usually 27"+ scale length instruments. So, I would guess no to the baritone strings unless you have an unusually long scale length. The baritone strings on a 25-25.5" scale would be floppy if tuned B-B or C-C and would be destructive tuned E-E.
John Lewis
PostPosted: Sun May 31, 2015 10:12 am
First name: Ringo
There's one way to find out: put them on the guitar and tune it up. I'm assuming you want to tune much lower than standard... if you're tuning E to E be prepared for catastrophic failure with all the extra tension.
Intonation could be an issue as you go up the neck... bigger strings are stiffer and may need a lot more compensation than your current saddle can provide. Also the nut slots will probably need to be widened. My guess is that the tone will be quite wonky with strings too fat for the scale length, but you never know... you might like it.
PostPosted: Sun May 31, 2015 10:20 am
First name: Big
Last Name: Jim
That I understand, my reference wasn't clear. It does put the bridge further back in the lower bout . And on a deep body guitar, what difference if any that would make .
PostPosted: Sun May 31, 2015 11:26 am
If you are considering putting a different neck on the guitar body then if for example the twelve fret clear guitar has a 650mm scale length (25.6") then a 725mm (28.5") scale length neck joined to the same body with fourteen frets clear would have the bridge in pretty much the same position on the body. This scale length is very much in baritone guitar territory and a 5" deep body should work well.
PostPosted: Sun May 31, 2015 3:59 pm
First name: Big
Last Name: Jim
Appreciate the specs , I wanted to do something without changing neck. Currently scale is 25. 5
PostPosted: Sun May 31, 2015 4:20 pm
If the guitar has a long soundboard and a deep body the baritone strings might get you down to a low C tuning without too many problems
PostPosted: Sun May 31, 2015 4:38 pm
First name: Big
Last Name: Jim
Worse case scenario, I waste time and have to replace nut and saddle. When I originally laid this guitar out I set the sound hole for 14th fret mount and then made a 12th fret neck .... Rookie doofuss move so now the distance from bridge to center of sound hole is 7" with a 5" body depth . this puts the bridge dead center "or close" in lower bout
PostPosted: Sun May 31, 2015 8:58 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
are baritone guitars ideally suited for down tuned playing?
PostPosted: Sun May 31, 2015 9:17 pm
First name: Big
Last Name: Jim
Don't know , I have 0 experience with baritone. That's kinda why I went with this thread.
PostPosted: Sun May 31, 2015 9:45 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I've got done playing styles that would be suited to this
PostPosted: Mon Jun 01, 2015 7:37 am
First name: Big
Last Name: Jim
? Auto correct ?? Lolololol
Users browsing this forum: bobgramann, doncaparker and 30 guests
